September 2, 2021 at 2:37 pm
Mansoureh
SubscriberDear friends,
I need to understand for simulating compression test with nonlinear isotropic hardening criteria, which physics performance should we use?
mechanical or nonlinear mechanical?
September 2, 2021 at 3:40 pmRahul Kumbhar
Ansys EmployeeBoth of these option should be fine as both of them generate qudratic elements. Using nonlinear preference , you may get more smooth mesh and slowly changing mesh. Whereas using Mechanical preference, you might get coarse mesh and transition would be fast by default.
September 2, 2021 at 4:27 pmMansoureh
SubscriberThank you very much.
Viewing 2 reply threads- The topic ‘physics preference’ is closed to new replies.
6545
1311
