August 27, 2021 at 5:54 am
d08941008
SubscriberHello, I noticed that there's a script file mentioned in the demo of Waveguide Bragg Grating (https://www.lumerical.com/learn/video/waveguide-bragg-gratings-and-resonators/) to modify the grating structure considering the Fraunhofer effect of lithography . But I can't find this file in the application gallery zone. Could you please tell me where to download it? Thanks.
August 31, 2021 at 6:24 pmTaylor Robertson
Ansys EmployeeHello RyanChung The files are associated with the lithography update are available under the Photolithography video. https://www.lumerical.com/learn/video/photolithography-simulation/.
Lumerical offers some capabilities in photolithography simulation. Our model is mainly based on Fraunhofer diffraction at the photomask, where the mask is assumed to be a very thin metal without plasmonic or polarization effects. It allows users to simulate the photolithography effects by defining some key inputs Photomask (the desired geometries)
Projection NA
Spatial coherence factor
Resist threshold
which represent some key elements in a photolithography simulation, such as the illumination optics, photomask, projection optics, and photoresist.
The following steps are used to run a photolithography simulation in Lumerical
Create/import the structure, which will be used as the photomask
Input the photolithography parameters
Run the script file for photolithography simulation and generate the new structure
The following resources should cover you.
Recorded videos:
Photolithography Simulation
Subwavelength Grating Bandstructure
Related articles:
Photolithography
Bragg Gratings
January 17, 2023 at 8:04 amAkram Akrout akram.akrout
Once simulating the impact of Photolithography and after generating the GDS file, how to find the transmission spectrum of the initial design and the one with Photolithography effect?
In EME we can visualize be sweeping wavelength, however in the example it is an FDTD.Viewing 2 reply threads- The topic ‘Photolithography simulation of WBG’ is closed to new replies.
3892
1414
1256
1118
1015
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
