November 7, 2024 at 9:53 am
r.abbasi
SubscriberI have analyzed two connected bodies with a hinge in AQWA and conducted a frequency domain analysis. Besides their Pitch RAO, I also need the phase information. Could you please let me know in which file I can find it?
I searched in the FREQUENCY.LIS file, but it didn’t mention the structure numbers.
(for clarification I have attached RAO's and phases that I mean)
Thank you.
November 8, 2024 at 10:59 am
Shuangxing Du
Ansys Employee -
November 11, 2024 at 4:31 am
r.abbasi
SubscriberThanks for that. When I run the new setup on both the current and previous setups, once it is successfully completed, will the new Freq.lis file be replaced, or do I need to close and save the setup at the end?
November 11, 2024 at 9:29 am
Shuangxing Du
Ansys EmployeeOnce you have run the current setup, the current results will overwrite the previous ones in your project folder. However, your previous results are temporarily stored in the backup folder. When you exit Workbench, the window below will pop-up, and if you clcik on "No" to not save your current project, the previous setup will be restored into your project folder.
4783
1565
1386
1242
