August 30, 2026 at 8:26 am
can.sumeyye
SubscriberI am using Fluent 2022 R2 (v222, build 10212) for a transient LES/WALE simulation with Partially Premixed Combustion, FGM, C-equation, Non-Adiabatic Energy Treatment and Finite-Rate turbulence-chemistry interaction. Radiation is off. The mesh contains 10.69 million polyhedral cells.
The physical configuration contains a hot burnt pilot adjacent to the cold premixed burner stream. The pilot must remain in the model.
Current pilot boundary:
- mass-flow-inlet
- mass flow = 1.43e-4 kg/s
- Total Temperature = 2000 K
- Mean Mixture Fraction Z = 1
- normalized Progress Variable C = 1
- both variances = 0
Z=1 represents the premixed CH4/air reactant stream at equivalence ratio 0.8; Z=0 is ambient air.
Original numerical symptom
We initially investigated persistent
"Maximum PDF table enthalpy exceeded"warnings and a very large high-temperature population. At a trusted saved checkpoint:- T > 2200 K: 607,239 cells
- T > 2400 K: 454,109 cells
- T > 2600 K: 282,747 cells
- T > 2800 K: ~103,329 cells
- Tmax = 2849.998 K, exactly the upper temperature limit of the current PDF table.
Of the cells above 2400 K, 82.3% have cell enthalpy above their local PDF-table maximum enthalpy. Above 2600 K this fraction is 87.8%.
Numerical/model sensitivities already tested
We have already performed a substantial set of controlled sensitivity tests, so we would particularly appreciate guidance beyond generic URF/time-step recommendations:
- Time step: reducing dt from 2e-5 to 1e-5 s did not materially change the solution at matched physical times.
- Energy URF: reducing Energy URF from 1.0 to 0.8 produced essentially the same high-temperature population; in a clean sibling comparison it was slightly worse rather than better.
- PDF enthalpy resolution: increasing the enthalpy coordinate from 20 to 80 points (H80) produced only a modest reduction (~5% in T>2400 and ~3% in T>2600 populations at comparable times); the underlying behaviour remained.
- Adaptive Grid Refinement of the PDF table: AGR = 0.10 changed the high-temperature counts by less than approximately 0.5%.
- Extrapolation: turning solution extrapolation OFF produced essentially the same result. At the same physical time, T>2200 / T>2400 / T>2600 counts were 676,287 / 485,091 / 288,294 versus 671,044 / 482,312 / 288,988 in the comparison branch.
- Poor-mesh numerics: Poor Mesh Numerics correction was tested and had essentially zero effect on the high-temperature population.
- Operating density: changing the specified operating density to a representative value produced essentially identical early behaviour.
- Pilot temperature/flow adjustments: increasing the pilot temperature toward the experimental ~2230 K worsened the PDF-enthalpy warnings; reducing the pilot flow did not eliminate the problem and in one test increased the warning count.
- Heat-gain range: increasing the heat-gain range moved the PDF temperature ceiling from ~2425 K to ~2850 K, but the solution then populated temperatures up to the new ceiling rather than removing the underlying anomaly.
Global transient mass balance closes to approximately 1% of the net boundary flux. All walls are adiabatic and radiation is off. Therefore we have found no indication that a gross mass imbalance, wall heat input, Energy URF, time step, table resolution, extrapolation, or isolated poor cells are the primary origin.
Key boundary-enthalpy diagnostic
We then measured the pilot boundary state directly.
On all pilot inlet faces:
- F_T = 2000.000 K
- F_Z = 1
- F_PREMIXC = 0.1221857, corresponding to the burnt maximum of the transported un-normalized progress variable
- F_H = +2.015300e6 J/kg
Fluent's own native heat-transfer report independently gives:
pilot heat-transfer / pilot mass-flow = +2.0153e6 J/kgso this value is not a UDF post-processing artefact.
However, cells at essentially the same burnt thermochemical state (Z≈1, normalized C≈1, T≈2000–2050 K, enthalpy inside the PDF bounds) have:
H ≈ -2.064e5 J/kg
and
Pdf_Adiabatic_Enthalpy(Z=1)also gives approximately -2.0644e5 J/kg.Therefore the pilot boundary carries approximately:
+2.219 MJ/kg more total enthalpy than the corresponding burnt state.
The anomalous enthalpy is already present on the pilot boundary and in the first downstream cell layers, whereas the main heat-release-rate peak occurs farther downstream. Thus the excess enthalpy is not first generated inside the main reaction zone.
Furthermore, the pilot boundary value +2.015300e6 J/kg agrees almost exactly with an independently measured PDF upper enthalpy value on the unburnt (C=0) side, +2.0152998e6 J/kg. We regard this only as an observation; we have not determined whether it represents clipping/limiting, a particular T→H inversion path, or another mechanism.
The main cold velocity inlet provides a useful sanity check: T=300 K, Z=1, C=0 gives F_H≈-2.0644e5 J/kg. We recognize that this does not isolate boundary type because the main inlet is a velocity inlet whereas the pilot is a mass-flow inlet.
Mesh/modeling questions
The flame-region mesh size is approximately 0.30 mm. Our estimated laminar flame thickness is approximately 0.534 mm. Poor-mesh-cell treatment had essentially no effect, but we would like your assessment of whether the spatial resolution itself is inadequate for this Partially Premixed FGM/C-equation LES formulation and could materially contribute to the observed temperature field.
More importantly, our PDF table uses adiabatic premixed flamelets with the Non-Adiabatic Energy Treatment / heat-loss-gain enthalpy extension. Because a ~2000 K fully burnt pilot stream enters immediately adjacent to a ~300 K premixed reactant stream, is this application within the intended validity of that standard non-adiabatic FGM treatment?
Could the large local enthalpy difference between the hot burnt pilot and cold main stream require true non-adiabatic flamelet generation at multiple reference temperatures/enthalpies (or burner-stabilized flamelets) rather than an adiabatic flamelet manifold with enthalpy extension?
Requested guidance
We would like a specific recommendation for Fluent 2022 R2:
- How should a physically required ~2000 K fully burnt pilot be specified in Partially Premixed FGM?
- For a mass-flow inlet with T0=2000 K, Z=1 and normalized C=1, why does Fluent assign approximately +2.0153 MJ/kg total enthalpy instead of the ~-0.206 MJ/kg adiabatic burnt-state value?
- Is this expected behaviour, a known 2022 R2 limitation/defect, or an incorrect boundary/model specification on our side?
- Is a different inlet treatment required for the burnt pilot?
- Is our ~0.30 mm flame-region mesh insufficient for this model?
- For a hot burnt pilot immediately adjacent to a cold premixed burner stream, should we generate genuinely non-adiabatic flamelets instead of using adiabatic flamelets with the heat-loss/gain extension?
- What is the recommended correction that preserves the physical pilot and avoids the observed PDF-table enthalpy exceedance/high-temperature population?
We can provide the full case/data checkpoint, PDF table, native Fluent flux reports, UDF diagnostic and detailed sensitivity results.
September 7, 2026 at 1:26 pm
Richie Mathew
SubscriberHello,
Pilot flame is an injection of hot burnt gases used to increase the probability of flame ignition. In your case, you have set the mixture fraction of the pilot flame to Z = 1. Because of this, you are not injection hot burnt gases, rather hot fuel into the system. To accurately mimic the pilot flame, you need to set the value of Z as Z_stoi which represents the burnt gases at stoichiometric quantities. The stoichiometric value of Z can be either calculated or can be seen in the Flamelet file generate from Fluent (.fla file format). Keep C as 1 and variances as 0. Since temperature at the inlets are different (between pilot and inlet), you will have to use non-adiabatic flamelets.Â
If the issues still persists, using TUI commands go to /define/models/species/non-premixed-combustion-expert. There are a few options under that menu, just change the heat loss and/or gain fraction (the first if you hit the lower limit, the second if you hit the upper limit), these can be increased to 1. After this, regenerate the PDF table.
For the fluid domain, ensure that the domain is large enough to capture the entire flame. If it is not possible, the outlet should be at such a height that the reverse flow from outlet (if any) is not affecting the flame core.Â
Since, your injection is axial to the domain, I would suggest you to use poly-hexcore instead of pure polyhedral cells just to reduce numerical diffusion. From the contour image, I see that the cells at the top seem very coarse in comparison to the flame centre. Use the same cell size for the entire flame region, especially when using LES models.Â
Coming to the turbulence models, first run a RANS/URANS simulation and then use that as the initialization for LES. I would suggest you go for SBES model (4.15. Stress-Blended Eddy Simulation (SBES)) as you might not need to over refine the mesh near the wall.Â
Lastly, check whether the geometry created is identical to the experimental domain. It seems like you are simulating a bluff body flame, but the flame does not seem to be anchored at the bluff body. So, check whether the domain configuration is right.
