July 6, 2023 at 3:31 pm
July 7, 2023 at 12:35 pm
Ram Gopisetti
Ansys Employeehi ,Â
why are you repeating the cards?
do you have any refernce to your work ?
do you have any formal /guided training in LSDYNA in general ? and specific to paticel methods? , if not i suggest you first get the training started.
how can you run 16 cores dispite the licenses you hold?
cheers, RamÂ
July 7, 2023 at 5:04 pm
javat33489
SubscriberYes, of course I passed all the basic courses on Ls-Dyna.
I duplicated the material maps because:
If the material map (snippet) is only in the geometry section, then the SECTION and PART maps do not see it, and the material is not written to the K file.
I thought that if there are two places it will be useful both for Ls-Dyna WB and for recording with a K file.
I have also attached an ARCHIVE.
I put 16 cores, but in fact it works as much as the license allows.
July 18, 2023 at 9:05 am
javat33489
SubscriberLooking forward to your tips and advice! Thank you.
- The topic ‘Particles fly apart’ is closed to new replies.
5929
1306
