3D Design
3D Design
Partially sliced body within design modeler
    • kkyt2002
      Hello everyone.
      Does anyone know how to slice a body only partially?
      So I could have a contact region within one body.
      You can make a sketch, such as the circle, then Extrude slice material as shown below.
      Then you should select the two bodies and Form New Part so Shared Topology will connect a mesh across the two bodies that will become one part.
    • kkyt2002
      Thank you for your comment!
      I think my question was not clear enough.
      I would like to make a delamination inside a body.
      The delamination itself is not a body. it is a specific condition of a partial surface where meshes facing each other across the delamination surface are detached from each other.
      To make such a detached surface, I tried to use 'Slice'. However, The function 'Slice' couldn't be used to slice a partial face of a body. It always slices the whole body, and makes it into two different bodies.
      So my question is:
      Is there a way to define a surface area within 'One body', where meshes across the surface are detached from each other, but still have contact?
      There are many videos on Fracture mechanics and a Pre-meshed crack is what you want to search on. Here is one video.
      https://www.youtube.com/watch?v=QIeg4Yj-pEs
      If you want an elliptical crack shape, ANSYS has automated the creation of that crack in the mesh using the Fracture tool.
      https://www.youtube.com/watch?v=Pu3T09y8NVk
  • The topic ‘Partially sliced body within design modeler’ is closed to new replies.
