March 15, 2022 at 2:13 pm
System
SubscriberThis discussion was created from comments split from: Mesh dependence study using fluent. -
March 15, 2022 at 11:06 am
Atif0202
Hi there
I want to do a parametric analysis in fluent. I have created few input parameters and few output parameters. After a simulation run, i need to save project and check the option of "Use setting changes for current and future calculations". Otherwise fluent will return same value for each parametric run. But unfortunately I am always encountering the option as shown in figure and cannot select that option.
Any help or advice????
April 4, 2022 at 1:09 pm
Nikhil N
SubscriberHello,
May I know what are you parameterizing?
- The topic ‘Parametric analysis in fluent’ is closed to new replies.
1306
