December 4, 2019 at 2:52 am
xiaoling
SubscriberHi, I am using the DM Geometry in Ansys. what 's the difference between extruding a sketch as a body and firstly surfacing a sketch then thinning it? I found the results through two methods are the same. I am confused that why to choose the second method in some cases?
Besides, for the details of 'extrude', what's the standard to tell for the operation (select frozen), as thin/surface? (no), merge topology?(no)
I felt so confused about these parameter setting.
December 4, 2019 at 9:54 am
Forum ModeratorExtrude will create a solid body of a certain thickness. Not sure what you mean by the latter, can you post an image?
The remainder of the options depend on what you want to achieve. Have a look in the DM documentation, there should be examples.Â
December 4, 2019 at 10:35 am
xiaoling
SubscriberÂ
Thank you for your reply!
There are different methods to achieve the same geometries, like extrusion, or surface+thining.
I found the meshing results are different with the same geometries while different methods. like if I used the extruded one, the nodes and elements are much less than the case of using the surface+thining method.
So is it true that different geometry methods really affect the meshing results? I kept the other factors the same, like the meshing parameters.Â
December 4, 2019 at 11:35 am
Forum ModeratorAssuming the geometry is actually the same thickness and you've got the same preferences (and settings) in Meshing the geometry generation method shouldn't matter.Â
December 4, 2019 at 12:00 pm
December 4, 2019 at 1:25 pm
Forum ModeratorCan you post images?Â
- The topic ‘parameter setup for Ansys DM geometry’ is closed to new replies.
6279
