October 8, 2018 at 7:01 pm
jonsys
SubscriberHello,
How can I make a parametrized load/displacement (e.g. P6) or geometrical parameter (e.g. P5) be dependant on P1?
I know that P5 can be made dependant using "Parameter/Desing Assignments" in Design Modeler but I wanted to explore more the Parameters set.
And I was wondering, probably P6 doesn't work in this case because of the different units.
Any suggestion is welcomed.
October 8, 2018 at 8:25 pm
Sandeep Medikonda
Ansys EmployeeIt probably is. Why are your units changing?
I've created one and it seems to work without any problem
Sandeep
Best Practices to post on the Student Community -
October 9, 2018 at 6:30 am
Aniket Chavan
Forum Moderator@jonsys you need to add expressions as shown by Sandeep above, in addition to that P1 is mm and P6 is in MPa, So you'll need to multiply by required units to P1 in order to use it in P6
Check the following image:
- The topic ‘Parameter Set; parameter dependency’ is closed to new replies.
6420
