July 28, 2021 at 12:32 pm
NimaNZ
SubscriberHi everyone
I was wondering if for setting up the case for the parallel solver, just specifying the number of cores in the setting is enough? or there should be something done in the partitioning tab in fluent?
July 28, 2021 at 1:50 pmRob
Forum ModeratorIt's usually enough. You can set the options to use a different scheme and add load balancing but I'd leave those alone until you know why you want to change from the default.
July 28, 2021 at 2:10 pmNimaNZ
SubscriberI have subdomains into my domain; that means there are 26 enclosures in the computational domain. Each has different sizing and number of mesh. Is it still fine to go for the default method?
July 28, 2021 at 3:03 pmRob
Forum ModeratorThe partitions shouldn't encapsulate so check the partitions when you open the solver.
July 28, 2021 at 3:27 pmNimaNZ
SubscriberSure, many thanksViewing 4 reply threads- The topic ‘Parallel and Partitioning’ is closed to new replies.
5779
