September 16, 2024 at 8:30 am
li-heng.chang
SubscriberI'm designing PB phase metalens. As the first step, I need to send a right-hand circularly polarized light as input, and calculate the phase of left-hand circularly polarized light. For the input, I set up two plane waves with orthogonal polarization and a phase difference of 90 degrees. However, is there a way to set the output of the detector so that only left circular polarized light is detected?
Thank you very much in advance.
Best regards,Â
Li-Heng
September 16, 2024 at 3:45 pm
Guilin Sun
Ansys EmployeeThe input method is correct;
the monitor has data of Ex,Ey and Ez, you can post process the data to get the circular polarization result based on the definition of the left- or right- polarization.
1307
