Electronics
Electronics
Overriden by other boundaries problem in HFSS
    • enfrkn
      I try to simulate an antenna with square rings that include multiple lumped elements, like one in the the figure attached. Only difference from the figure is that I use total of 4 lumped elements (serial RLC) in every side of the ring. When I check the 'Boundary Display' it says for corresponding lumped elements to be invisible to solver. Why is that ('Overridden by other boundaries. Invisible to Solver')? How can I solve it?
    • Aymen Mzoughi
      Seems that the radiation BC is not set up correctly so that outer PEC is touching lumped RLC (PEC takes precedence over RLC)
      Just a reminder that you may use Ansys Community Feed to develop your network and foster community by joining the appropriate community group and making connections. If you are interested in Electronics content, please join the Electronics group (link - https://innovationspace.ansys.com/community/groups/?electronics-community/)
