3D Design
3D Design
OVERRIDE TRANSPARENCY
    • Wayne Remnant
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      I need to have my model transparent when I am trying to show a flow simulation.  The old version had a menu with an override transparency option.  I can not find this in the 2021 version.
    • subashni.satish
      Hello wremnant You can select the component and set it to Transparent from the menu on the bottom left og your screen
    • Wayne Remnant
      I have tried that.  I can change transparency when the simulation is not running.  When I select a solve view the model will only run in a wireframe view.
    • Wayne Remnant
      Problem solved.  It turns out I need to switch between explore and model to have the solid model show in the simulation.
  • The topic ‘OVERRIDE TRANSPARENCY’ is closed to new replies.
