Process Integration and Design Optimization
Output parameter as an exported text data file
    • Hus.Ansys
      Hello and hope all are doing well.
      Any Idea on how to be able to output results as an exported text files.
      My input parameter is the thickness below:
      And I want for multiple input thickness values to export a text file of the below surface temperature result
      Any idea how to since normal input/output parametric study is limited to certain output values like min/max single results?
      Thank you!
    • Aniket Chavan
      please check:
      https://ansyshelp.ansys.com/public//Views/Secured/corp/v242/en/act_script/act_script_examples_write_contour_results_onto_file.html
      -Aniket
      Forum Rules & Guidelines
