January 21, 2025 at 12:01 amdkmenendSubscriber
I am running a transient case with mesh adaptation to capture a detonation wave. I am running simulations on a high power computing cluser and I am getting Out of Mem Errors. I am running 1.4 million cells on 48 cores. What is the potential causes of the OOM error? I have noticed that they tend to crash after running for ~24 hours. Thanks for your help.
The slurm out file says "slurmstepd: error: Detected 1 oom_kill event in StepId=34836945.batch. Some of the step tasks have been OOM Killed."
January 21, 2025 at 9:53 amRobForum Moderator
If you're repartitioning and saving data/images it's possible the solver hasn't freed RAM up as well as it might. I'm assuming you can resume from the (auto)saved case & data?
- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Script Error
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- convergence issue for transonic flow
- Running ANSYS Fluent on a HPC Cluster
- Point exception in erosion calculation
1882
802
599
591
366
