TAGGED: Add Material, Discovery AIM, Heat Transfer, thermal
June 10, 2018 at 10:03 am
yan.eng
SubscriberHi,
How can I use the solver Command to define orthotropic conductivity in thermal analysis. I am new to it, and I don't know how to define it, thank you.
Thank you.
June 11, 2018 at 4:58 am
Naresh Patre
Ansys EmployeeHello Yan Manashirov APDL commands can be passed through Solver Command option for defining orthotropic conductivity. In the example shared in this post , when you click on Physics - Solver Options - User Command, you can see the APDL commands specified under /PREP and /SOLU Start - Just Before Solve section. For more details on these APDL commands, please check out the help document. -
June 11, 2018 at 7:12 am
yan.eng
SubscriberThank you,
and one more thing, what is the symbol of thermal conductivity in MAPDL, I guess kx,ky,kz?
June 11, 2018 at 12:17 pm
Naresh Patre
Ansys EmployeeYan Manashirov Yes, the symbol you guessed are the correct ones.
- The topic ‘Orthotropic Thermal Conductivity’ is closed to new replies.
1306
