August 11, 2020 at 3:25 pm
Fred2233
SubscriberHello everyone,nI want to modell a corrugated steel pipe in Ansys as a simple cylinder with orthotropic properties. I started modelling a simple plate and I found Ex, Ey and Gxy, exy, with formulas from literature and I put these values in ansys to than compare the thin plate (with orthotropic properties) and the corrugated plate. My problem is that to modell a cylinder I need other values such as Ez, shear modulus Gyz Gxz and Poison?s ratio eyz ,exz. I know that it has not so much to do with Ansys but I dont know how to find this from Literature and to apply it in Ansys. Or Should I try different values to see which is more relevant to approach the solution of a corrugated cylinder. If anyone has had the same issue or has knowledge in this direction I would be happy of every advice! Many thanks in advance!n -
September 16, 2020 at 9:17 pm
April Wang
Ansys EmployeeHi,nYou can find an example of orthotropic material with parameters in ANSYS Help.nArraynYou can also find it in Ansys Help by Mechanical APDL Technology Demonstration Guide: CHAPTER 29: ROCKET NOZZLE EXTENSION SIMULATION: OPERATIONnnNote that for orthotropic material, there's a relationship between Young's modulus and poisson's ration.u_yz/E_y = nu_xy/E_x, nu_zx/E_z = nu_xz/E_x, nu_yz/E_y = nu_zy/E_z, Search keyword orthotropic poisson's ratio can give you some details.nnAlso, if your material is transversely isotropic, it put some restriction on the poisson's ratio and sear modulus.u_xy/E_x = nu_yx/E_y, nu_yz= nu_zy, G_yz = E_y/2/(1+nu_yz, search keyword "transversely isotropic materials" will give you some details. n
- The topic ‘orthotropic material properties of sinusoidal corrugated steel’ is closed to new replies.
Ansys Innovation Space
1283
1117
1068
983
