Process Integration and Design Optimization
Optis Lang – Multi analysis method
    • bcchul1
      I am performing sensitivity analysis by connecting "AEDT" (Maxwell). to Optislang
      Parametric analysis seems to be progressing one by one.
      Is there a way to analyze multiple things at the same time?
    • igandiko
      When you open the AEDT node, at the bottom of the window, click on show advanced options and try increasing "designs per execution". I hope this helps.
      • bcchul1
        Thank you for your reply.
  • The topic ‘Optis Lang – Multi analysis method’ is closed to new replies.
