March 14, 2024 at 11:50 am
kessemzamir
SubscriberDear Sir/ Madam,I'm currently working on a periodic structure consisting of two waveguides with grating, in FDTD using Bloch boundary condition.I want to do an optimization on the waveguides' and gratings' parameters in order to get some feature in the dispersion relation.I would like that my cost function will be a function of the eigenvectors of the transfer matrix of a unit cell of the structure (which depends on the waveguides parameters). I wasn't able to find how to do a simulation with optimization that its cost function is related to the eigenvector. Is there a feasible approach to accomplish this task?I appreciate your help,Kessem -
March 18, 2024 at 6:14 pm
Guilin Sun
Ansys EmployeeFOM (Figure of Merit) can only be a scalar, one value from the built-in particle swam optimization. eigen vector is a not a scale factor. So you will need to manuliplate the eigenvector to form a FOM.
For more than one FOM value, other third tools may have multi-targets algorithms that you might use. Currently Lumerical can use Matlab and Python. You may explore them.
March 19, 2024 at 9:11 am
kessemzamir
SubscriberDear Guilin,
Thank you for your answer. Indeed I intend to manuliplate the eigenvector so my cost function (FOM) will be a scalar, sorry if it wasn't clear.
I am encountering difficulties in translating this concept into code. Specifically, I am unsure about the implementation details regarding the extraction of eigenvectors and subsequent optimization within the FDTD framework.
Could you possibly provide me with an example or point me towards a similar simulation that demonstrates the manipulation of eigenvectors and subsequent optimization? Any guidance or resources would be greatly appreciated.
Thank you for your assistance.
March 19, 2024 at 7:26 pm
Guilin Sun
Ansys EmployeeI guess you know how to get the eigen vector: https://optics.ansys.com/hc/en-us/articles/360034925793-eig-Script-command
You will need to get the eigen vector in an analysis group; in "model"; or in Custom FOM if possible:
https://optics.ansys.com/hc/en-us/articles/360034922953-Optimization-utility
examples:
Inverse design of waveguide crossing
- The topic ‘Optimization in Lumerical FDTD ’ is closed to new replies.
5734
