December 27, 2020 at 11:21 am
singhvipin4291
SubscriberI know parametric optimetrics,nCan you explain me sensitivity and tuning with an example..or refer me a problem to practice samen -
January 4, 2021 at 1:19 pm
Praneeth
Ansys EmployeeHiArray,nThank you for reaching to us and we appreciate your patience.nPlease refer the Sensitivity Analysis Overview, Setting Up a Sensitivity Analysis, Tuning Overview and Tuning a Variable under the Optimetrics chapter in the HFSS Help document for detailed illustration on the topics.nAll the very best.nBest Regards,n -
January 16, 2021 at 4:04 pm
singhvipin4291
SubscriberThanks, Mr. Pmunaga nI am not able to define my output variable. so please provide me with some notes so that I can define my output first and the sensitivity analysis of a variable on it.nnEx. Let T= k*b/c and I want to calculate the sensitivity of c on T.n -
January 18, 2021 at 8:28 am
Praneeth
Ansys EmployeeHiArray,nPlease refer to Specifying Output Variables section of Post Processing and Generating Reports chapter in the HFSS Help document for detailed illustration on the topics.nAll the very best.nBest Regards,n -
January 19, 2021 at 5:44 pm
singhvipin4291
SubscriberHloo pmunaga, nthere is no such file in HFSS. Please provide the link for the Specifying Output Variables section of Post Processing and Generating Reports chapter in the HFSS Help document.n -
January 19, 2021 at 6:04 pm
Praneeth
Ansys EmployeeHi Array,nYou can find the said section and chapters in the HFSS Help PDF document available from the tool. nScreenshot is attached for your reference to access the HFSS Help document.n
All the best.nBest Regards,n
January 20, 2021 at 4:35 am
singhvipin4291
SubscriberI know that sir. but first of all, I am working on maxwell 2D, not on HFSS. Secondly, I have HFSS pdf doc of v10 and no such sensitivity analysis in those documents.nPlease help me maxwell 2D as possible with a simple example of T=ka/b. where a and b are variable and T is output parameter on which sensitivity of a and b is to be analyzed. nn -
January 20, 2021 at 8:06 am
Praneeth
Ansys EmployeenPlease let me know the version of the tool you are using.nBest Regards,n -
January 21, 2021 at 2:47 pm
singhvipin4291
SubscriberAnsys /EM /19.0n -
January 21, 2021 at 3:01 pm
Viewing 9 reply threads
- The topic ‘optimetrics sensitivity and tuning’ is closed to new replies.
1565
1386
1236
