LS Dyna
LS Dyna
open up workbench LSDYNA to change how it works
    • Dennis Chen
      I like to ask if it's possible for Ansys to share how exactly does workbench LSDYNA writes out certain keywords and how I can create my own version of writing out input deck.   For example, I like to create an object that writes out the *node keyword based on a set of (x,y,z) coordinate based on a coordinate system that I created.    This *Node wouldn't be a real node in the GUI but it will show up as a node in LSPP because *NODE exists.
      there are many other examples I like to do myself.
      I am considering writing my own ACT extension to change the behavior of workbench LSDYNA but I would really like to have a place to start, as opposed to starting with nothing.
      Would it be possible to share something?
    • ErKo
      Hi
      We have a lot of info here (takes some time to learn act extensions scripting).
      Chapter 14: Customizing LS-DYNA using ACT
      (look at method also stream.Write(‘*Your *node here….and change as needed :)\n’) )
      Should you require some help please post here in the script forums:
      Home – Community Forum
      Erik
    • Dennis Chen
      Hi Erk, thank you for that link to the doc! I actually have not read this so I am very happy to read this :)
      Best
