LS Dyna
LS Dyna
Only Red Dots in Explicit Dynamics
    • kDart
      Please help. I am running ANSYS ACADEMIC 2019 R3. Is it possible to render the results of my "end mill cutting a block of aluminum" as the standard element color scheme I usually get with static structure, etc.? More importantly, I am concerned with the stress results, etc. of the aluminum block, not the cutting mill.
      I have almost maxed out my allowable 32000 elements. And it seems (see attached .PNG file) that the element size is small enough to be completely removed as it fails.
      Without this aspect, my paper is lacking tremendously. I don't know what to do, if I even can do anything.
    • kDart
  • The topic ‘Only Red Dots in Explicit Dynamics’ is closed to new replies.
