September 23, 2025 at 10:02 pm
Dennis Chen
SubscriberHello, I am trying to create an example model to represent the workflow for a one-way thermal mechanical model where I run the thermal part first to basically map a temperature field to a body.  secondly, I want to transfer this temperature field to the structural step so the stiffness of the structure is altered by this temperature field.  I want to ask about the load_thermal_binout file.
1) if I run in SMP, can I not use load_thermal_binout?
2) if I run in MPP, I have a binout file by default.  However, when I load the data, the solver just crashes with no messages
3) below is the exact keyword I used but maybe I have an issue with the alignment of time steps. ...
*LOAD_THERMAL_BINOUT
$# deftemp
  273.15
$# Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â filename
thermalstep.binout0000
$ $  startt    tsf   tmpoff   nidoff
$Â Â Â Â Â Â 0Â Â Â Â 1.0 Â Â Â 0.0 Â Â Â Â 0
September 24, 2025 at 3:04 am
Dennis Chen
SubscriberHello, to add, I want the structural side to be run explicitly and I am looking for an example of this to see where I've made mistakes in my example models.  Thank youÂ
3942
1414
1272
1119
1015
