Old time step value to set boundary condition
    • BiomedModeller
      Dear all,
      I am trying to assign Windkessel model (RCR) to an outlet of an artery. To do this without Fortran routines, I require to access to the value of pressure in last time step. There is a workaround using "Probe" function and monitor points. However, it cannot be used to define an expression to set the boundary condition. Any hint how to solve this issue?
      Thanks
    • DrAmine
      You can use workaround using arithmetic average over last two time steps with the probe expression. As ASC you can check that on the portal.
    • BiomedModeller
      Dear Amine,
      Thanks for the reply.
      I did do that and it worked well. The problem is CFX does not allow me to use it as an expression to define boundary condition. I want to use the value of old pressure in outlet BC definition and CFX says you cannot use probe in BC definition. What do you suggest?
    • DrAmine
      Try assigning that To algebraic variable. If it does not work let us know.
    • BiomedModeller
      We have done that as well. Gives the return code 1 error bellow:
       |                  User Defined Monitor Information                  |
        Monitor Point: MP current Q
                              Arithmetic Sum
        Monitor Point: MP current P
                              Arithmetic Sum
       |                    Writing crash recovery file                     |
         Details of error:-
       Error detected by routine MAKDAT
       CDANAM =  LVAR CDTYPE =  INTR ISIZE =  123
       CRESLT = OLD
       |                An error has occurred in cfx5solve:                 |
       | The ANSYS CFX solver exited with return code 1.   No results file  |
       | has been created.                                                  |
    • BiomedModeller
      The Ansys manual emphasizes for the probe that:
      Note:  The probe function does not calculate a value for a statistic until the defined interval is complete. As a result, a “probe” function that retrieves a statistic from an expression-based monitor:
      • Should not be used in a CEL expression for a quantity that is required at all times, for example, a boundary condition.
    • BiomedModeller
      Any update please?
    • DrAmine
      You can provide a good starting value for that variable if used all time.
      If still not helping you will need to use User Fortran.
Viewing 7 reply threads
  • The topic ‘Old time step value to set boundary condition’ is closed to new replies.
