oil reservoir model
    • user deleted
      Hi everybody
      I am simulating oil flow in porous media (draining oil by horizontal well).and i faced with several problems:
      1  how can i obtain values of inertial resistance and viscous resistance (for oil reservoir conditions)
      2 after visualization of results pressure field aroud the wellbore is disturbed. Is this due to incorecct boundary conditions or input parameters?
      can anyone give advice?
    • Raef.Kobeissi
      Hi Fanil,
      Check this document and look at these 2 sections for the calculations:
      The Link is: https://www.sharcnet.ca/Software/Ansys/17.0/en-us/help/flu_ug/flu_ug_sec_bc_porous_media.html#RelativeViscosityInPorousMedia-D248F878
      6.2.3.7.7. Deriving Porous Media Inputs Based on Superficial Velocity, Using a Known Pressure Loss
      6.2.3.7.8. Using the Ergun Equation to Derive Porous Media Inputs for a Packed Bed
    • user deleted
      Thank you sir!
      If we consider the reservoir with 900 mDarcy permeability, 20% porosity, density 937kg/m3, 150m3/day production rate, reservoir pressure 6 MPa and well pressure 3MPa, then
      (6*10^6-3*10^6)=Kl*(0.5*937*v^2)   V25% - is this value un m3/day or m/s? (m/s depend on well radius)
    • Raef.Kobeissi
      The V value is a velocity value (m/s)
  • The topic ‘oil reservoir model’ is closed to new replies.
