3D Design
3D Design
Offline chm help
    • user deleted
      Hello!
      We discovered, that in case if end-user does not have an access to Internet and hence could not use online-help, there is an option to use offline chm help-files, which are available in different languages.
      It would be very kind, if you could share such files for SpaceClaim and Discovery Live (2019 R1) in Russian language.
      Do you have any plans to include these files in installation package like it was done for ANSYS products (I mean Local Help package, available at Customer Portal for such cases)?
      Thank you beforehand! Looking forward to your reply.
    • Naresh Patre
      Hello  Nikolay Staroverov
      Regarding your questions on offline help, I will check with the concerned team and let you know.
      Meanwhile, you can check out the English version of offline help document in this article .
    • Naresh Patre
      I have send the CHM files through Secure Transfer email.
      After downloading a .CHM, you may need to "unblock it" before you can use it. This is a common security measure that most computers will enforce on files that came from a different computer.
      To Unblock a .CHM:
      1. Right-click on the downloaded .CHM file and select Properties.
      2. At the bottom of the General panel, check Unblock.
      3. Click OK and reopen your .CHM.
  • The topic ‘Offline chm help’ is closed to new replies.
