TAGGED: convertsurface, shell, solid-surface, surface-body, surfaces
June 17, 2021 at 8:14 am
jordi.marce.nogue
SubscriberHi! I have a volume in spaceclaim and I want to extract the surrounding surface to perfrom a shell model. I detach the volume and I got a lot of surface bodies (which are in fact the patcehs of the CAD volume). I am trying to merge all the surfaces in one surface but I cannot. How I should do this process? How I can obtain the surrounding surface of a volume in a single body)?
June 17, 2021 at 11:28 ampeteroznewman
SubscriberIn SpaceClaim, go to the Workbench tab and click on the Share button. This will create a single connected mesh in Mechanical. You don't need to merge the faces.
If you want to merge some faces for some reason, you do that in SpaceClaim on the solid volume. I think Merge Face is on the Repair tab. When the solid has fewer faces, copy/paste the faces to Surfaces and delete the Solid.
June 17, 2021 at 2:04 pmjordi.marce.nogue
SubscriberOk. Thanks! I did not see this "share" option
Viewing 2 reply threads- The topic ‘Obtaining the surrounding surface of a volume in Spaceclaim’ is closed to new replies.
4929
1638
1386
1242
