LS Dyna
LS Dyna
Obtaining material parameters from a stress strain diagram (Ls-Dyna)
    • goktug.yilmaz
      Hi everyone,
      I have a parameter list below to do analysis on Ls-Dyna. However, I am struggling with obtaining or calculating some of them. For example, definition of the tangent modulus is that:
    • ramgopisetti
      Hi Array , The answer to your question is an quite an complex ( gettign the tangent modulo of different grades of the Aluminium) unless you have tensile test data, if youhave such data you can use the following forum for calcuating the Tangent modulo
       E_tan_Calculated / E ratio may be closer to an Elastic-perfectly plastic case.
      E_tan_Calculated = [(1+%EL/100)*S_ult - S_yield ]/ [(ln(1/(1-%RA/100)))- (S_yield/E)]
      %EL= % Elongation
      %RA= % Reduction in Area
      E = Modulus
      The strengths are self Explanatory.
      If you don't know the %RA you can approximate as follows
      %RA =200*%EL/(100+2*%EL)
      If you have access to Granta Material library, you might get compleat Plasticity modelling Parameters.
      Comment down your response for futher help.
      Cheers, Ram
    • goktug.yilmaz
      Thank you very much for your help dear Array . You have helped a lot. I am very grateful. However, what about other parameters? There is actually little information about the "hardening parameter(beta)" for example.
    • Ram Gopisetti
      Hi Array , i encourage you to check the *MAT_003 *MAT_PLASTIC_KINEMATIC in LSDYNA documentation, It clearly explains how to derive those parameters, for K,n you need to so the curve fit with True stress=K.True strain^n and optimize the K,n coefficients. for beta you can assume your material undergo Kinematic hardening and use 1 .
      Cheers, Ram
    • Kyle
      Hi goktug.yilmaz, I am new user in LS-DYNA software. I have a question for the output of LSDYNA. Basically, I have used the software to do tnesile test in numerically and I have an issue about output. My question is how to output the engineering stress/strain, and/or true stress/strain? Looking forward to hearing from you!
      Sincerely,
      Kyle
    • myeasygrader
      Can you make grading software?
Viewing 5 reply threads
  • The topic ‘Obtaining material parameters from a stress strain diagram (Ls-Dyna)’ is closed to new replies.
