August 5, 2025 at 5:09 pm
odurney
SubscriberI am using OAPs in my current design. Can Zemax draw an OAP with uniform edge thickness and a flat back surface? I would like to create OAPs with edges that are perpendicular to the back surface and close to uniform thickness all the way around the periphery. I only see a standard wedge shape and 'curve' shape available. Please advise.
August 6, 2025 at 7:32 am
Niki Papachristou
Forum ModeratorHi Oderney,
Thank you for reaching out to us! May I ask you if you have explored the Draw surface properties option within your designs? I think that this mighrt be a good solution for you: Draw (surface properties), it also includes the "Flat To Next Surface" option as well.
Let me know if that helped you or you need further assistance.
Kind Regards,
Niki
August 7, 2025 at 3:40 pm
odurney
SubscriberYes, I have tried all the combinations in the Draw tab. Strangely, none of the choices from the 'Draw Edges As:' pulldown menu seem to do anything... they all appear the same in both the 3D Layout and Shaded Model viewers. However, the choices in the 'Mirror Substrate:' pulldown menu do change the form factor of the optic. But, none of them creates a uniform-ish edge thickness form factor. Aside from creating a custom volume in Part Designer, is there something I am missing. Please advise.
August 7, 2025 at 3:59 pm
Niki Papachristou
Forum ModeratorHi Odurney,
Can you send some helpful screenshots of your desing? This way I will try to replicate what you are trying to do and find a solution for you.
Kind Regards,
Niki
August 7, 2025 at 4:18 pm
odurney
SubscriberI cannot send this exact design... but I will create and send a simple OAP design. The problem is the same.
August 7, 2025 at 4:58 pm
August 14, 2025 at 7:54 am
tariq.islam
Ansys EmployeeYou can set the mirror substrate to “Curved”, which will give it a form factor similar to what you’re looking for.
You can also refer to the help file, which describes this in more detail. Draw (surface properties)
August 14, 2025 at 3:51 pm
odurney
SubscriberThank you for the tip. I am aware of the curved substrate choice. However, it is not what I want. If the edges of the substrate were perpendicular to the mechanical axis of the OAP, I could make it work. But, they are slanted… creating a curved parallelogram.
August 18, 2025 at 12:17 pm
Chris Normanshire
Ansys EmployeeHello.
If you convert you OAP from a Standard surface type to an Off-axis Conic Freeform surface then you be able to get the profile you require. Please see this post (Convert a Standard off-axis conic into an Off-Axis Conic Freeform | Zemax Community) on the old Zemax community for instructions on how to perform the conversion.
Kind regards,
Chris
August 18, 2025 at 3:33 pm
odurney
SubscriberThis looks similar to the 'curve' form factor, but the edges are perpendicular to the mechnical axis. Is it possible to have the back surface flat? I will practice. Thank you for the advice.
August 18, 2025 at 4:30 pm
August 18, 2025 at 4:37 pm
odurney
SubscriberThis is perfect. I am having some trouble following the instructions... need to figure out what is wrong. How would the instructions change of the OAP is after the focal plane?
August 19, 2025 at 4:46 pm
odurney
SubscriberHow can I contact Erin Elliott directly?
August 19, 2025 at 5:43 pm
odurney
SubscriberNevermind... I figured it out. Thanks everyone for your help.
August 19, 2025 at 11:17 pm
odurney
SubscriberActually, it would be helpful to understand how the OAP after the intermediate focal plane is adjusted to an Off-Axis Conic Freeform. Please provide instructions or an example. Thank you.
3792
1388
1188
1095
1015
