September 14, 2026 at 2:06 pm
Daniel.dejan.gunde
SubscriberHi,
I've had problems with Nvidia drivers compatibility in ICEM CFD for the last 2 years but after every Windows Update I found an older version of Nvidia drivers that worked. Since the last Windows 11 update I cant't find any. The symptom is very low frame refresh rate inside the application that makes the work impossible. Are you aware of this issue? Do you know a driver version that works with ICEM? My graphic card is Nvidia T1200 Laptop.
Viewing 0 reply threads
