Nusselt number calculation for a channel
    • Dio
      I have Re=20,000, 165mm long, 15mm*15mm channel and trying to calculate Nu number.
      Tin=300K
      Charc. Lenght= 15mm
      300 W/m^2 heat flux at top and bottom surface
      Based on Nu= 0.023 Re^0.8 * Pr^0.4 = 0.023* 20000^(0.8)*0.7441^(0.4)=56.39
      When I select like below, result looks different.
      How should I calculate Nu? What can be the post processing expression formula?
      Thank you,
      Anton
      Look in the User's Guide for the exact definition https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v212/en/flu_ug/flu_ug_fvdefs.html (hint, use the Rules & Guidelines if you can't open the link).
    • Dio
      Thank you Rob, I was looking for formulas like below videos. I hope these will be usefull for future users.
      https://www.youtube.com/watch?v=mv3uDy7ZuCY
      https://www.youtube.com/watch?v=3YJhB7VmVEw&t=2s
      https://www.youtube.com/watch?v=YXkGqLC64-Q
    • DrAmine
      Videos might be helpful but always rely on the official and up to date Ansys Help Websites :)
    • Dio
      You are right you guys doing amazing job. I learned alot in this website.
Viewing 4 reply threads
  • The topic ‘Nusselt number calculation for a channel’ is closed to new replies.
