May 21, 2024 at 2:15 am
ito yosuke
SubscriberI am using ansys discovery under the license of snsys student. The website said that four CPU cores could be used, but only one is currently being used.
I would like to know if this is due to the student license, if the number of cores can be changed by changing the settings, or if it is incompatible with my computer. -
May 21, 2024 at 2:46 pm
Atharv Joshi
Forum ModeratorHi Yosuke,Â
Please check the File Menu>> Settings >> Physics >> Solver Settings >> Max number of processors.
You can try changing the max processors from the above path. Â
Thanks and Regards
Atharv -
May 22, 2024 at 2:56 am
ito yosuke
SubscriberThank you very much.
Problem solved.
- The topic ‘Number of cores used’ is closed to new replies.
- Add-in Error Excel
- Fileformats
- Discovery 2025r2 failed to initialize
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- racing royals
- New Computer
1494
1386
1209
