TAGGED: fluent, lithium-ion, msmd-battery-model, ntgk-model
April 29, 2021 at 10:14 pm
nitinchauhan93
SubscriberHello,
I am trying to model a Cylindrical Lithium ion cell using MSMD battery model (by NTGK empirical model). I have 3 discharging curves for 4 different temperature levels. When I use the parameter estimation tool to input the files, a (warning: Y-value for DOD = .......... is negative, please check the input data!) comes up (see image). These warnings come up for each temperature.
May 12, 2021 at 1:45 pmwcao
Ansys EmployeeHi Nitin The reference capacity is explained in the theory guide:
The link is here: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/flu_th/flu_bat_model_ECMs.html
Please make sure you are supplying the discharging data to the parameter estimation tool. If possible, can you share the plot of your discharging data? Usually such error is directly related to the the data you used. Thanks.
May 12, 2021 at 4:35 pmnitinchauhan93
SubscriberThanks . Really appreciate your help. I attached the voltage vs time graph which I am using. The Y-axis is the voltage and x-axis is the Time in seconds. I am giving each of these graph separately in TGK parameter estimation tool. Any help would be helpful.
Viewing 2 reply threads- The topic ‘NTGK parameter estimation negative Y coefficient’ is closed to new replies.
6575
1311
