January 13, 2025 at 9:35 amanujchauhan10339Subscriber
This is a very Recent article (open Acccess). I am not able to set the overset mesh as I want to perform the similiar simulation.Â
May anyone please guide me how to do the overset mesh as the author has done in this paper.Â
Implementation of nozzle motion for material extrusion additive manufacturing in Ansys Fluent
https://doi.org/10.1080/17452759.2024.2397816
Or any tutorial recommendation or any Meshing file. They have uploaded the motion udf file. The animated video is also available for the same as author has uploaded on his linkdn page.Â
I would appreciate your help.ÂÂ
January 13, 2025 at 10:09 amRobForum Moderator
Overset is covered in one of the tutorials in Fluent's Help system. You'll just need to replace the 6DOF with fixed motion track. Â
If that's VOF the solution isn't going to be overly stable, and you will need to do some reading on the model settings to try and get it working.Â
January 13, 2025 at 10:20 amanujchauhan10339Subscriber
Thank you, I will check that tutorial and try to do it.
- Non-Intersected faces found for matching interface periodic-walls
- Fluent fails with Intel MPI protocol on 2 nodes
- Cyclone (Stairmand) simulation using RSM
- error udf
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
- UDF, Fluent: Access count of iterations for “Steady Statistics”
1416
599
591
565
366
