February 23, 2023 at 5:03 am
Roberto
SubscriberHelloÂ
Sheet 1 of 2 autofill notes doesn't work, just drops the page number.
Correct compilation must be 1 of 2
Regards
​ 🛈​ This post originally contained file attachments which have been removed in compliance with the updated ​ Ansys Learning Forum Terms & Conditions​ -
February 23, 2023 at 5:07 am
Charudatta Bandgar
SubscriberHello Roberto
Let me check.
Regards.
February 23, 2023 at 5:19 am
Charudatta Bandgar
SubscriberHello RobertoÂ
If my understanding is correct, you are using number of sheets (english translation) instead of sheet number.
This will give the number of sheets your file has.
This gives the sheet number, although not as 1/2 and 2/2, but just as numbers, 1,2.. etc.
Let me know if my understanding of your issue is correct.
Regards.
February 23, 2023 at 5:29 am
Roberto
SubscriberCharudatta Bandgar Yes this is the command I use but it doesn't work
Once it works it said 1 of 2 ,,,, 2 of 2
if I use the default field of a ready-made drawing format it works otherwise if I create it from new it doesn't work
Video link https://www.screencast.com/t/5MIL4glv
February 23, 2023 at 6:18 am
Charudatta Bandgar
SubscriberRoberto As far as I understand, this is the expected behaviour. Let me still check with the team, I will get back to you.
February 23, 2023 at 8:22 am
Roberto
SubscriberHello
Charudatta Bandgar If this is the expected behavior it would make no sense to have two equal fields one called sheets , and another number of sheets.
I remember that in the old versions it wasn't like this and there was a differenceregards
March 17, 2023 at 6:41 am
Roberto
SubscriberHello Charudatta Bandgar
you have some news?
Regards
- The topic ‘note autofill field error’ is closed to new replies.
5889
1306
