October 30, 2023 at 6:10 am
KANTUBHUKTA HEMANTH HARI KISHORE
SubscriberDear ANSYS Support Team,ÂÂ Â Â Â Â I hope this email finds you well. I am writing this to seek your assistance regarding an issue that I am facing while doing Transient analysis, for a tube(100mm length) and a coil placed inside the tube, in ANSYS Maxwell. There are two such models are shown, viz.Â1. Single Stage - tube and middle coil.2. Multi Stage - tube, middle coil, and two end coils(connected in series).ÂFor the excitation of coils, I've used a current dataset obtained from an experimental setup.ÂThe magnetic field along the inner surface of the tube (i.e., along distance at a particular time) is unsymmetric and has more ups and dips even though my modal is symmetric. I've shown the magnetic field distribution for both models.ÂWhy is it unsymmetric? I want to get a peak at the center and symmetrically reducing curve to either side.ÂI would greatly appreciate it if you could assist me in getting a symmetric curve.ÂÂÂ -
October 30, 2023 at 3:53 pm
Timos
Ansys EmployeeHello, firstly it's important to ensure that the geometry of your model is perfectly symmetric. Secondly, the meshing of the model plays a crucial role in the accuracy of the simulation results. A poorly defined mesh can lead to inaccurate and unsymmetrical results.
- The topic ‘Not getting a symmetric magnetic field for a symmetric modal in ANSYS Maxwell’ is closed to new replies.
