TAGGED: 2D, ansys-student, mesh-generation, structural, workbench
August 8, 2021 at 11:06 am
KaranBhuta
SubscriberAugust 8, 2021 at 11:21 ampeteroznewman
Subscriber2D Quad Meshing is done on surface bodies. You have a been meshing a solid body. You need to work in SpaceClaim or DM to extract surface bodies from the faces of the solid body. In SC, that is very easy to do: select the face and type Ctrl-C then Ctrl-V.
After you have all the faces you need, you may need to do some editing to extend them to a common intersection point. Once that is complete, delete the solid body. Then you would turn on Shared Topology. That is very easy to do in SC: on the Workbench tab, click the Share button.
August 8, 2021 at 12:29 pmKaranBhuta
SubscriberIt worked . Thank you
Viewing 2 reply threads- The topic ‘Not able to generate a mesh’ is closed to new replies.
