January 1, 2025 at 1:25 pm
muhamed.sewidan
SubscriberHi,
I wanted to simulate the power coupling using Lumerical MODE between the TE mode of a waveguide and an external laser mode. So I set the properties of the laser beam and mode, and I tried to investigate the overlapping. The value was very small, so I optimized the position, but still, the power coupling is very low (3.5e-6).
This should not be the case, since when the laser is closer at 0 um from the waveguide, the power coupling should be maximum (around 100%). The further I go, the less power I have.
So I found out that I needed to normalize the values.
How can I do that?
The configuration of the solver is: mesh cells 200 * 200
Boundary conditions are: PML
I appreciate any help you can provide.
January 2, 2025 at 3:30 pm
Kirill
Forum ModeratorDear Subscriber,
There is no need to normalize the modes when performing overlap analysis. Please refer to the following resources for more details:
Additionally, the following example demonstrates the optimization of coupling between a fiber and a waveguide: Edge coupler. Please review it to see if it might be helpful for your application.
Best regards,
Kirill
5754
