April 11, 2022 at 5:56 pm
Mariah Ha
SubscriberHello,
My question is regarding lumerical transient example which is in lumerical courses (/courses/index.php/courses/lumerical-charge-small-signal-ac-and-transient-simulations/lessons/transient-simulations-lesson-2/) . Why the norm length in charge solver is set to "100 microns" for the 2D simulation for normalization, although the length of the device in the third direction (y) is 2 microns only not 100 .
Thank you.
April 11, 2022 at 7:43 pmGuilin Sun
Ansys EmployeeThe norm length in charge solver set to "100 microns" is the default, arbitrary choice I believe. This value is needed to get the current value, as internally the solver calculates the current density, not the current its self. Therefore the result "current" can be "arbitrary" depending on this norm length. The current density is fixed though.
If you know the length in the 3rd dimension, you can use it.
Viewing 1 reply thread- The topic ‘“norm length” in lumerical transient simulation example’ is closed to new replies.
6745
1324
1067
