August 8, 2023 at 5:41 pm
Maryam Tabbakhh
SubscriberHi,
I made a model of three layers with linear and nonlinear material properties at the top middle box. Other layers are linear elastic. I used the material properties of 079. I put the stress-strain curve in the material properties. actually the nonlinear soil is surrounded by elastic soil and then I added PML. But the thing is that the waves reflect back to the domain. I applied a pulse in the middle point of the nonlinear soil but the animations shows that they reflect back and I compared the results with if the red box is linear soil and have the same material properties of the first layer and I attached the results. The results are so discouraging. Do you have any recommendation for me?
August 9, 2023 at 10:46 pm
Ushnish Basu
Ansys EmployeeI can offer only general advice on this forum -Â
The nonlinear material should behave linearly near the outer boundaries, and the elastic material properties of each elastic or PML layer should match the elastic properties of the corresponding non-linear material.
- The topic ‘nonlinear soil’ is closed to new replies.
5649
1885
1404
1303
