August 2, 2022 at 7:54 pm
August 3, 2022 at 10:04 pm
Guilin Sun
Ansys EmployeeAeff means (modal) effective area? if you have the mode data you can calculate it based on your definition. If you are using FDTD to create such nonlinearity,it is likely that you can use a profile monitor at some location to record the field at the specified wavelength. Please try.
- The topic ‘Non linear Aeff in an SOI waveguide ?’ is closed to new replies.
1494
1386
1209
