June 27, 2023 at 3:09 pm
Zaid Abd Al-Hadi
SubscriberHey!
I read in Ansys help that the layers in a layered element will be as defined by the section command.
for example: if I have a 4mm thick laminate, meshed with a 1mm layered element. so 4 elements across the thickness,
and there are 4 layers defined in the section command.
does this mean that the whole model has 16 layers (4 layers for each element * 4 elements across the thickness) or only 4 layers?
what is the difference for the same situation but using a non-layered element?
best regards -
June 28, 2023 at 2:42 pm
Chandra Sekaran
Ansys EmployeeAre you modeling composite laminate. Typically 'layer' definition is used to define the various layers of a composite structures. So you could have a 4 mm thick element (in your case) but with section definition you can define for example, 3 layers. Each layer can use a different material, layer orientation and thickness but together the 3 layers will add up to 4 mm thickness.
July 1, 2023 at 7:28 am
Zaid Abd Al-Hadi
Subscriberthanks for replying,
yes, I'm trying to model a composite plate using reinforcing elements, but I can't get it right.the commands are as follows:
MP,EX,1
MP,NU,1
MP,DENS,1MP,EX,2
MP,NU,2
MP,DENS,2
ET,1,SOLID185
KEYOPT,1,3,1Â Â Â Â Â !LAYERED SOLID
MAT,1
ESYS,0
SECNUM,1SECTYPE,1,SHELL
SECDATA,0.001,1,45, ,L1
SECDATA,0.001,1,-45, ,L2
SECDATA,0.001,1,-45, ,L3
SECDATA,0.001,1,45, ,L4
BLOCK,0,0.1,0,0.1,0,0.004Â Â Â Â !PLATE WITH 100X100X4 (mm)ESIZE,0.001
MSHKEY,1
MSHAPE,0
VMESH,ALLSECTYPE,2,REINF,SMEARSECDATA,2,1.97E-11,5.2961e-6,0,0,LAYN,1Â Â Â Â Â Â Â Â Â Â Â Â Â Â !MAT, FIB. DIA., SPACING, KCN, THETA, PATT, LAYER#ÂSECDATA,2,1.97E-11,5.2961e-6,0,0,LAYN,2SECDATA,2,1.97E-115.2961e-6,0,0,LAYN,3SECDATA,2,1.97E-11,5.2961e-6,0,0,LAYN,4SECCONTROL, ,1, ,ÂESEL,ALLEREINF
when the reinforcing section is defined as "2", (i.e sectype,2,reinf), it gives error: the specified reinforcing section 2 for section 2 is a LAYn pattern with layer number greater than one and must be overlaid with a shell.Â
if the reinforcing section is defined "1", it gives error: reinforcment No.2 in section 1 for REINF element xxxx specifies a layer number which is greater than the total number of layers defined for the base element 2.Âdespite, my goal is to use a shell section and a reinforcing section in the same element, what is the best way to do this?
thanks in advanceÂ
- The topic ‘Non layered Vs. layered element’ is closed to new replies.
5069
1771
1387
1248
