December 22, 2023 at 10:41 am
Ratnadeep Nath
SubscriberIn fluent, I am using moving mesh involving rotor and stator. However, for a given case, the node ccordinate in rotor changes after a given timestep. so is there any way that I can get same node ccordinates after a few time step.
Note: After completion of 1 complete cycle also, the node number changes
December 22, 2023 at 5:16 pm
Federico
Ansys EmployeeHello,Â
can you clarify your question? If your mesh is moving, wouldn't you expect for the node coordinates to change with time?
December 25, 2023 at 10:52 am
Ratnadeep Nath
SubscriberYes, the node coordinates will change but after completing a full rotation/cycle the node coordinates are changing whereas I thought that the node will occupy the same position after one complete cycle. Please clarify this portion.
January 8, 2024 at 1:20 pm
Federico
Ansys EmployeeHow far off are we talking about? And how are you ensuring that you are getting exactly 1 revolution?
January 11, 2024 at 10:39 am
Ratnadeep Nath
SubscriberBecaue I have given a particular value of mesh rotation and timestep. Secomdly for a given problem, a maximum 1 degree rotation per timestep is restricted. And that is how the number of iteration (say 1000) required for a complete rotation can be found. I am just checking the node coordinates after that particluar number of iteration like at 2000, 3000, 4000 etc.
- The topic ‘Node coordinates in moving mesh’ is closed to new replies.
5939
1307
