Node 1: Process 10469: Received signal SIGSEGV. when i use PUMA 3D
    • A1234
      Hello
    • Konstantin
      what type of a mesh are you have? Note the limitations on the usage of PUMA adaption discussed in Sec. 29.1.2. Polyhedral Unstructured Mesh Adaption of Fluent 2020 user guide.n
      There have been changes in PUMA from 2019R2 to 2020Rx so you may have hit an older problem. n
  • The topic ‘Node 1: Process 10469: Received signal SIGSEGV. when i use PUMA 3D’ is closed to new replies.
