April 26, 2024 at 11:52 am
Christijaaan
SubscriberHi!
I have an easy system (s. fig.) which is a harmonic torsional excited water filled tube.
Now I want to extract and average the nodal forces to calculate the torsional moment around the tube axis in a user defined cross-section (component, sliced like a salami :) ) in the pipe wall via APDL Postcommands. I tried the following but it didn't work out:
direc_axial   = 'Y'
direc_trans_1 Â = 'Z'
direc_trans_2 Â = 'X'CMSEL,S,ebene !Auswahl der Ebene als Komponente
*GET,n_nodes,NODE,,count !Anzahl der Knoten in der Ebene
*DIM,calc_array,ARRAY,n_nodes,13 !Init Array für flächengewichtete R/Im des Drucks und der Fläche (n_nodes x 2)set,1,i,,IMAG
next_node = 0
*DO,j,1,n_nodes,1
next_node = ndnext(next_node)calc_array(j,1) = ARNODE(next_node)
!Rotation um Rohrachse
*GET,r_trans1,NODE,next_node,LOC,direc_trans_1
*GET,r_trans2,NODE,next_node,LOC,direc_trans_2
r_abs = sqrt(r_trans1**2 + r_trans2**2)Â
u_rot = 1/r_abs*(-r_trans2*u_trans1 + r_trans1*u_trans2) !ACHTUNG: VZ in der Klammer ist entscheidend für die Phase
calc_array(j,11) = u_rot*calc_array(j,1)
!Moment um Rohrachse
*GET,f_trans1,NODE,next_node,RF,direc_trans_1
*GET,f_trans2,NODE,next_node,RF,direc_trans_1
f_rot = 1/r_abs*(-r_trans2*f_trans1 + r_trans1*f_trans2)
m_rot = f_rot*r_abs
calc_array(j,13) = m_rot*calc_array(j,1)
*ENDDO...
Actually it thought that this should be a hard task... but it turns out to be. Does anybody has some suggestions for an alternative workflow??
Greetings!!!
Christian
April 29, 2024 at 1:44 pm
dlooman
Ansys EmployeeA common, pretty easy way is to select a set of nodes at a cross-section and the elements on only one side of those nodes. Then fsum, possibly in conjunction with spoint will give you the moment at that location.
- The topic ‘nodal moment or force reaction in a tube with harmonic excitation’ is closed to new replies.
5824
