No image in Fluent simulation
    • Parthasarathi
      I'm not getting any images (scaled residuals) in the Fluent when the simulation is running. Tabs are blank. But when I could see the residuals image using camera->preview.
      Please help.
    • seeta gunti
      Please check whether did you turn on Plot option for residuals and report definitions.
      Seeta
    • Parthasarathi
      Thank you Seeta.
      I turned on the Plot option, I didn't get anything. Later I brought the convergence criterion to absolute, and run simulation again. There is no plot in the residuals.
    • Keyur Kanade
      Please check
      Solving - Run calculation - Advanced - Reporting Interval
      Make its value to 1.
    • Parthasarathi
      thank you Kkande.
      Then mentioned parameters (Reporting interval) are default.
      I'm using HP Elitebook 850 G5, intel i7-8650U CPU, 16 GB RAM, and Intel UHD Graphics 620. Is the specification is correct for using Ansys.
    • Keyur Kanade
      You can check at
      https://www.ansys.com/en-in/solutions/solutions-by-role/it-professionals/platform-support
    • Parthasarathi
      Thank you Admin.
Viewing 6 reply threads
  • The topic ‘No image in Fluent simulation’ is closed to new replies.
