September 20, 2021 at 10:53 amnoumanziaSubscriber
I am running into an error while running charge simulation " No electrical properties are defined for domain 3". I have tried to change the material in domain 3 but an error still exists.
Does anyone know what would be wrong in the simulation?
September 20, 2021 at 3:32 pmGuilin SunAnsys EmployeeIn CHARGE simulation, all geometries, including background air must be assigned a specific material. In your case It seems one geometry consisting domain 3 does not have material assigned . Please check related geometries including background.
September 20, 2021 at 4:14 pmnoumanziaSubscriberSeptember 20, 2021 at 6:01 pmGuilin SunAnsys EmployeePlease also check the related material's property and see if all the necessary, basic material parameters are given. Please also check message on the wall.
September 21, 2021 at 9:33 amnoumanziaSubscriberThanks! Basic material properties look ok, though they are different than what I found from other material models.
Anyway, I have changed the material as well to different materials but the problem is still the same. I think that means material parameters are not an issue?
I responded to your message on wall.
September 22, 2021 at 4:06 pmGuilin SunAnsys EmployeeMaybe you can first use the same material, then change one material at a time to identify which material causes such problem. Please also reply the wall message.
September 22, 2021 at 4:40 pmnoumanziaSubscriberHello, by unlocking the mesh in charge settings, this problem was resolved
Viewing 6 reply threads- The topic ‘No electrical properties defined’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Difference between answers in version 2024 and 2017 lumerical mode solution
- Errors Running Ring Modulator Example on Cluster
- INTERCONNECT – No results unless rerun simulation until it gives any
- Import material .txt file with script
- Trapezoidal ring
- Help for qINTERCONNECT
- Issues with getting result from interconnent analysis script
- Topology Optimization Error
- Edge Coupler EME Example Issue
- The two modes overlap the integral
Top Contributors-
1191
513
488
225
209
Top Rated Tags© 2024 Copyright ANSYS, Inc. All rights reserved.
