December 12, 2018 at 7:46 pm
abbas
SubscriberHello every one,
I generated an RGP table and during the process, I received the following warning.
How or where can I change the Newton iteration underrelaxation factor.Â
 | Temperature : "Constitutive Relation Under Relaxation"       |
 | Pressure  : "Newton Pressure Under Relaxation"
Best regards
Abbas
December 12, 2018 at 8:17 pm
DrAmine
Ansys EmployeeDoes the situation persist?
December 12, 2018 at 8:38 pm
abbas
SubscriberHi,
Yes, the situation persists. Therefore I am looking to reduce the relaxation factor.
Could you please let me know, how can I do that?
Thanks
December 12, 2018 at 8:57 pm
DrAmine
Ansys Employee Copy paste here the CCL of your binary mixture (right click on it and edit in command editor then copy).
December 12, 2018 at 9:08 pm
abbas
SubscriberÂ
LIBRARY:
&replace MATERIAL: CO2
Binary Material1 = CO2V
Binary Material2 = CO2L
Material Description = Carbon Dioxide CO2
Material Group = User
Object Origin = User
Option = Homogeneous Binary Mixture
SATURATION PROPERTIES:
Component Name = CO2L
Option = Table
Table Format = TASCflow RGP
Table Name = D
cfx/CO2-high.rgp
END
END
END
December 12, 2018 at 9:30 pm
DrAmine
Ansys EmployeeAdd following lines under the line containing Option =Homogeneous Binary Mixture:
 Newton Pressure Criterion = 1[Pa] (Default)
 Newton Pressure Iteration Limit = 150 (Default)
 Newton Pressure Under Relaxation = your value (1 is Default)
This would add the under-relaxation of NR-P. If you do not understand what is the meaning of Newton Raphson and why is it required then check some references. In general, one has to ensure that every single line in the setup is correct before starting under relaxation this numerical scheme.
I hope this helps. I leave feedback questions for other community members.Â
- The topic ‘Newton’s method warnings’ is closed to new replies.
6520
1310
