September 5, 2023 at 7:35 pm
Soikot Sarkar
SubscriberTo add new material in CHARGE simulation, there are some material type options such as 'semiconductor', 'insulator', 'conductor' etc. If I want to add a Transparent Conducting Oxide (TCO) material such as Indium Tin Oxide, which option should I choose?
Thanks
September 6, 2023 at 4:36 pm
Guilin Sun
Ansys EmployeeIn CHARGE it has only 3 types of materials: 'semiconductor', 'insulator', 'conductor' .
Any other materials must fall in those 3 types. If you believe its main function is for conducting current, then it is metal; if it does not transport charges, it is dielectric. The rest must have semiconductor material properties.
- The topic ‘New Material add in CHARGE’ is closed to new replies.
