June 5, 2020 at 4:17 am
Vahidebrahimi
SubscriberHi Everyone,
I have a hyperelastic biological model that based on literature, Neo-Hookean is the most suitable material.
Although, I have C10 and K values for Neo Hookean model from literature, when attempting to define the material in Ansys the inputs are "Initial Shear modulus" and "Incompressibliity Parameter D1 ".Â
How can I find "Initial Shear modulus" and "Incompressibliity Parameter D1 " using C10 and K available? And is D1=2/K (where K is the bulk modulus?)
I also have Stress-Strain Experimental data (uniaxial) for the curve fitting if needed.
Thanks in advance for your advice
Regards
June 6, 2020 at 3:36 am
peteroznewman
SubscriberYes, D1=2/K
- The topic ‘Neo Hookean Constants’ is closed to new replies.
